I have the Split Screen plug and use it on the effects panel.
I have 1 monitor for the interface and two projectors on Nvidia 7900 card configured on Windows display properties as 2 and 3.
In resolume I have them as full screen but they clone the image I have on the small interface screen despite the split screen plug in being there,
any idea how i can stretch the image with the plug in over the two projectors as its meant to be doing?
thanks
split screen - rather urgent need help
maybe its me not understaanding (its sunday afternoon afterall) but im not sure what you mean by "splitscreen plug" are you trying to take an image and put the elft half through one projector and the right half through the other? to my knowledge, this is not possible through Resolume. You can make each of the projectoirs output the layers of your choice through the screen setup options, but not half a layer.
movebandit
Splitscreen Plug
The Spiltscreen Plugin doesnt work as a splitter. Its specially desinged for a 2x2 Splitscreen with monitors used as 4 in a row.
