What's the best settings to export VJ clips?
AWM
Post by AWM »
Just exported my clips from Final Cut Pro on my Mac as AVI's, Type: Cinepak, 25 Fps, 24 keyframes ps, 90 kb ps, quality:high and depth:millions of colours.
I transferred them into Resolume on my PC with an external hard disk and the files worked fine on the PC monitor but the colour looks wrong on my projector? The images look dark and parts are very green?
What could this be?...Nearly there!
Thanks.
edwin
Post by edwin »
hi alex,
it's probably not a problem of the way you exported your clips.
But you can try using indeo for one or two files to see wether you experience the same problem, make sure you use the same clips to compare the colors.
it might be a problem with the settings on your projector or p.c , but that's hard to say without knowing more about your setup.
Cheers
Edwin
