hi there resolum users- i need your advise and experience with rendering video clips. the demofootge in resolum 2.4 are CINEPAK by SUPERMAC 25fps 320X240. i'm editing with vegas 6.0d and in rendering option i have CINEPAK by RADIUS. maybe there is a diffrence between the two CINEPAK codecs but i cant get a clear video after rendering. i renderd with the exact param but the video gets pixled!
where can i get the CINEPAK BY SUPERMAC codec? what converting software u use that has cinepak supermac in it?
						still can't figure quality cinepak...
i used Gspot
to get the same specs as in the demofotage, the only diffrence is that i render with radius codec couse i cant get the supermac on the web
can you post here what software u use to edit and convert?
Edwin i really need your help on this one, where to get cinepak supermac or how to edit the same perfect cinepak video as you did???
[Edited on 3-12-2006 by poki]
				SuperficiaL
Cinepac = 256 colors...
indeo/MJPG = milions of colors
so Cinepac is in some cases better only for filesize/Decode-time reasons.
so if u have lots of colors in your footage or gradients or something use Indeo/MJPEG and if u have a white square bouncing use Cinepac
Grtz,
Superficial...
Grtz,
Superficial...
				PiXelSHift
