What is the best format to play
napalmskatterjazz
Post by napalmskatterjazz »
VJ Newbie here of course. I have some AVI fractal loops that drop frames and slow down my computer way more than all my other footage and swf's. One of which is a 30sec loop and is like 1.7Gb of drive space. I want to convert file types or change resolution so they are smaller and smoother playing. What format should I change them to and what size pixelperinch type stuff. Thanks
edwin
Post by edwin »
Hi napalmskatterjazz,
choose your resolution for instance 640x480 or 400x300 and render your footage using Indeo 5.1 or Cinepak (we recommend indeo for better quality).
check out the Preparing Media section in the online manual for more detailed settings:
http://www.resolume.com/support/manual/ ... ng%20media
Cheers
Edwin
