M3 Max MBP Performance Issues
da1t0n
Post by da1t0n »
Hello,
I have a M3 Max with 40-gpu cores and 48gb of ram. Running on the latest version of Arena.
I have a 4K composition with a single 4K output.
I have a 19 layer comp, with 19 slices all done via slice routing instead of routing to the composition.
I currently have one slice outline effect, two .png converted to DXV (unsure if necessary, but trying anything atm), and two 4k clips converted to DXV.
With no clips selected, I am at about 43% on memory, 48% on the GPU, and about 75-85fps.
Whenever I fire the column with the clips mentioned above, performance tanks to 44% on memory, 97% on GPU and about 43 fps.
The only effects being used is AutoMask and Blur. I do not understand why my performance is bad when this computer is definitely capable of more.
Any help and information is greatly appreciated!
Re: M3 Max MBP Performance Issues
Sounds odd indeed. What version are you using? Can you send us a simplified and consolidated composition on mail@resolume.com
