currently running resolume on my macbook pro via bootcamp. after fooling around on osx, i've come across the following dilemma...
is resolume capable of using quartz composer files? if so that would mean a whole world of fun and games especially if you could control parameters of the quartz file from resolume just like you can with flash. if not then its a damned shamed and is there anything that could be done to make it compatible? does saving the .qtz file as a .mov work?
all the best
shanks
