BPM Rate - Parameter Animation
DJMW
Post by DJMW »
Putting in a request for a new Parameter Animation: BPM Rate.
Currently BPM Sync progresses with each beat, so, for instance, using it with a Speed parameter will see the speed increase from 0 to 100% in every bar.
It would be incredibly useful to have a BPM Rate in addition to BPM Syc: with BPM Rate a BPM 20 would map to 0% parameter and BPM 500 to 100% parameter.
This would allow creation of generative clips that adjust parameters according to the total BPM value, rather than each beat. Currently the only way to do this with speed is to render a clip and then set the Transport to BPM Sync, which of course removes many live parameters from the clip. It would also be useful to be able to apply it to parameters other than speeds.
I have tried to find a work-around to this but haven't had much luck.
