Advanced output failure
flappy
Post by flappy »
I run resolume arena for a church with a led wall. We just had stage set change and rebuilt and remapped our wall. After 10 minutes the output blacks out on our screens but when I open output>advanced it auto comes back and it fine. this is looping problem every 10-ish minutes. did not happen last stage.
2022 Mac Studio
M1 Max 32gb ram
Sonoma 14.7
novastar vx1000
Arena 7.22.5
salahaddin
Re: Advanced output failure
Post by salahaddin »
I am experiencing an issue with Resolume Arena where the display sequence changes unexpectedly after restarting the application.
I have three projectors and am using a PNY NVIDIA RTX A4000. I have configured an LED screen with three DP outputs with EDID, and Resolume Arena is set up to manage the output.
After restarting Resolume Arena, the projection outputs do not maintain the same sequence as configured prior to the restart. Each time I restart, I need to rearrange the display.
Could someone please advise me on a possible solution?
Thank you for your assistance!
vygintas_m
Post by vygintas_m »
I have similar setup. 3xDP to Novastar H2 video splicer/led controller.
I noticed same problem after i change GPU, Resolume doesn`t hold screen number after restart, for me, solution was restart LED processor. After that OS had new display number. Re-arranged in Resolume, and they hold same config.
salahaddin
why Resolume support team not responding our support requests
