video-out problem with MacBook Pro
DinkyToys
Post by DinkyToys »
Hi Guys,
I sill have problems with the latest release of Resolume with my MacBook Pro.
I use an VGA --> Video converter. But the screen of Resolume goes wild. 'knipper de knipper' when i start it up. The latest beta release works great. But the latest version does have some nice things.
levon
Post by levon »
have you tried deleting the screen settings xml? else i cant think of anything
gradek
Post by gradek »
What kind of VGA to Video converter are you using?... the MacBook Pro uses DVI out. So I am a bit confused as what type of output your are using. Do you mean DVI-Video?...
The drivers for apple's DVI-Video adapter is not supported in windows as of bootcamp 1.11. and the DVI-VGA apple adapter, for me has only worked on some CRT monitors but not any LCD device, like flatscreens and projectors.
