after effects and resolume
armitageshanks
Post by armitageshanks »
have been mucking around in after effects recently and am able to create animations (using trapcode's soundkeys) that are responsive to bass, mid and treble (for an example see this: http://www.trapcode.com/movies/drums.mov). this is on the basis that the sound file is embedded in my after effects project.
is there any way (perhaps through exporting my AE file to flash, for example) that you could import these AE files, one way or another to resolumeso that these animations can react on the fly to resolume's FFT data?
If not then such a feature would be pretty sweet for a future version.
all the best,
armitage
VJ Nexus
Post by VJ Nexus »
learn to do the same types of animations in flash. It's not too hard - you then need to learn the actionscript to apply to it.
