Synesthesia scene control Wire patch
RhythmEchidna
Post by RhythmEchidna »
Hi all! Absolute Wire noob here, please help.
I'd like to create a patch to select different scenes in Synesthesia from Arena clips but have no idea where to start. I've used All Hell Breaks Loops' Synesthesia meta controls effect and it works brilliantly, allowing seamless control of meta parameters in Synesthesia from the Arena interface.
Now I just need a clip effect I can load in Resolume, mapped to my controller, that when I trigger the clip it sends OSC to Synesthesia to select the desired scene. I don't think it's an overly complicated process, I just don't know (and can't find a tutorial on) how to go about it.
What nodes do I need to use to create the patch with the actual scene selection commands?
Do I need to set the OSC port numbers in the patch?
What else have I not thought about yet?
There is a way I've found to use TouchDesigner as an OSC bridge between Resolume and Synesthesia, but if possible I'd rather save the load on my laptop and use a Wire-generated patch natively in Resolume.
Cheers!
