Hey all,
I just received a new APC40 MKII and while mapping I realized that when clips are activated they change the associated pad color to orange and I understand why that's helpful.
My problem comes in with the wire patch I built that remains active between multiple triggers that happen inside of the patch itself. This causes the multiple pads mapped to triggers in the patch to change to orange and not revert back to their mapped color. They occasionally change back to the chosen color after numerous presses or being pressed gently but that doesn't seem like an intended feature so I suppose this post doubles as a bug report.
All of this is assuming this is a feature on Resolumes side of things and not a built in behavior of the APC. If anyone has encountered this or found a solution please weigh in, thanks!
Cheers,
Ripescreens
APC40 MKII Color Pads
Ripescreens
Re: APC40 MKII Color Pads
Okay I just had a healthy dose of RTFM and I now see that this is all intended behavior and all I had to do was assign the on state to the same colour as the off state since that clip remains active. Read your manuals folks, lest you wind up like me making pointless forum posts..
