Hi.
Firstly, I should say that I know VERY little about computers.
I was running Resolume on a Acer Ferrari 3200 and it was ok until one point. Now when I run Resolume on it the computer simply shuts down after a little while.
I want to buy a new computer, which can be Mac as well. Could you please recommend me what should be my next buy?
Thanx a lot,
m
lost in the harware market
hi
your machine may have problems with its motherboard, which means you
really need a new computer. it is also possible that it only needs good cleaning.
enough dust inside the machine can cause that kind of a problem. i recommend
that you take it to the nearest computer service and let them check it out.
good luck,
suvanto
good luck,
suvanto
