so my question is. if i use a 500gb sata drive instead of my 160 sata drive. when im performing will it take longer for clips to be found in the 500 then then the 160? im running a 160 7200 rpm. should i upgrade it to 10000rpm if im running resolume? would that be better?
by the way im loving the prog. still in demo mode.
