TV Tuner problem
TV Tuner problem
I try Pinnacle Stereo TV tuner composite video in as Live video input source, but there's no option for selecting TV, Composite or S-Video. Any help!
I had the same problem.
Solution that worked with my card:
First start the software program that you received with your pinnacle card and select tv composite or s-video in that program.
after that close the program and start resolume. resolume uses the input that you selected with the other program.
