[fixed] Missing Freeframe
gpvillamil
Post by gpvillamil »
A small number of Freeframe plugins are not loading, namely Intrinsic FX Particle1 and Particle3 effects. They are in the plugins folder, but don't appear in the Freeframe effects list.
Also, in the transitions effect section, I cannot select some of the Intrinsic mixer plugins. I can select Inside-Us-All and VisualVinyl mixer plugins, however, selecting the Intrinsic ones selects the last of the Inside-Us-All mixers instead.
[Edited on 16-3-2007 by bart]
Jaymis
Post by Jaymis »
Hi gpvillamil. These effects work fine for me in 2.41.
Running on an Athlon64 X2 4200, Radeon X1600.
gpvillamil
Well, I did a clean install with only the Intrinsic effects, and I am still not getting Particles1 and Particles3 in my list of Freeframe effects. Only Particles2 is appearing.
gpvillamil
Nevermind, got it working. I needed to delete the Resolume 2.4 folder in My Documents, then it worked.
aah great ;-)
