hi there,
i'm currently fiddeling around with the resolume demo, and i was wondering if anyone would like to share their oxygen8 midi setup, as i still have one those gathering dust in the basement.
thanks all.
oxygen8 midi setup?
well thats all i run with resolume. 1 try left so not good but it works good!
i use mine like this!
from right to left i have the first 15 keys to trigger the first 15 channels and then use from left to right again the first 5 black keys for the other channels.
then for the rotary knobs i use 3 of them for the layer opacities and 2 for effects parameters and 3 for the layer speeds! so all in all you got 8 used.
oh just so i don't forget i assign the last 5 black keys to effects. im in the process of an m-audio trigger finger! i really like the oxygen 8 to use for vj-ing. its small and has everything you need for when you first start vj-ing
ok, i'm still trying to figure out how this works.
teh oxygen 8 has this nifty self centering pitch control wheel. i thought that would be rather handy to scratch through clips. you know,
center -> normal play
pitch up -> fast forward
pitch down -> backwards
unfortunately, resoluem doesn't seem to recognize any midi signal coming from this pitch wheel. can anyone confirm this?
