Wire Stats to have ms as well as %
cat
Post by cat »
As the title says Wire Stats to have ms as well as %
While its good to see which node is the heaviest, would it not be useful to see what the load is as well?
This node is 70%! But actually thats 70% of very little, for example.
The stats at the bottom of wire, give you some suggestion, but some of the is editor, and it is hard to know how efficient your patch actually is, except by quitting wire and loading in arena and seeing how many multiples you can run.
Ciandoeslights
Re: Wire Stats to have ms as well as %
Post by Ciandoeslights »
I initially thought that's how stats would work. Definitely wouod like this
