lag on clip trigger
armitageshanks
lag on clip trigger
Post by armitageshanks »
is it just me or does everyone get a lag/delay when they trigger a clip? is this just a simple case of my mbp not having a fast enough hard drive?
i use mjpeg or mov codec so not thinking this is the cause.
it's quite annoying when you want to trigger a clip to land on a beat...
is this solved by getting a fast external hdd that you connect via firewire?
cheers guys,
armitage
[Edited on 16-4-2007 by armitageshanks]
nrrtv
Post by nrrtv »
is your clip long? Its almost certain that a long clip in a slow HD will have a delay. Even worst if is mov, I think.
If is not long, check your hd speed(RPM). A 4200 or a 5400 is not a perfect choice. Ideally, you should stick with a 7200+
Are you using avi files with your mjpeg codec? I know it sounds silly but I didn't have a good experience with those. Try to use picvideo MJPEG. I think is the best out there.
And yes, and external hardwire can resolve this. Just use an usb 2.0 or firewire and you are ready to go :)
armitageshanks
cheers man. have opted for a lacie quadra 500 gb. gives me the best of both worlds as its firewire 800 and if thats still not fast enough then i can always go sata if needs be...
nrrtv
Post by nrrtv »
Nice! :)
