Hide settings on the dashboard
Timoxy
Post by Timoxy »
Hi all,
I have a quick question. I'm currently working on a "scoring board" for Resolume, to be used in alpha over football matches. I'm building this project using Resolume Wire.
However, when I use it in Resolume, there are a lot of parameters (like position, scale, etc.) that appear by default, and I’d like to know if there’s a way to hide or remove some of them. The interface gets cluttered, and I don’t want all those settings to be visible.
i just want 2 or 3 options not 50 ^^
Thanks in advance.
cat
Re: Hide settings on the dashboard
Post by cat »
Don't use float ins etc? Or use groups in your dashboard, and put all the ones you want to use in 1 group, and the other in another
Timoxy
Post by Timoxy »
Hi cat, thanks you to reply, i made few groups in the dashboard, but.... i don't see groups in resolume arena, it's normal ? you have the same problem ? i use the last official 7.23
Timoxy
Post by Timoxy »
My bad, i put parameters behind group, but we need to drop on the group...
