M-AUDIO TRIGGER FINGER + WINDOWS VISTA + RESOLUME
eleztron
Post by eleztron »
HI
I HAVE A PROBLEM WITH THE M-AUDIO TRIGGER FINGER.
MY LAPTOP IS A SONY VAIO VGN-FE41Z WITH WINDOWS VISTA & I HAVE A CONTROL SURFACE MIDI (M-AUDIO TRIGGER FINGER) BUT... WINDOWS VISTA TELL ME "USB DEVICE NOT FOUND" & THEM RESOLUME DONT LOOK THIS DEVICE, BECAUSE THE SYSTEM NOT FOUND THE SAME.
PLEASE, HELP ME...
SEE YOU HERE...
eleZTron
cyril_l
Post by cyril_l »
try to turn off the power management for all the USB hub root in the windows device manager.
If that doesnt work you might need a usb expantion card or powered usb hub (that solved the problem for my laptop)
