EAccessViolation
maurop88
EAccessViolation
Post by maurop88 »
When I open resolume 2.41 or 2.4 I get the splash screen like frozen for a while, an then this error appears:
"Exception EAccessViolation in module resolume.exe at 0009F126.
Access violation at address 000A0126. Read of address 000A0126"
and only this is what I get in the logfile:
"Logging started: Viernes, 11 Mayo 2007 - 15:30
start up 11/05/2007 03:30:45 p.m.
create my documents folder if not exists for current user 11/05/2007 03:30:45 p.m.
create application data folder if not exists 11/05/2007 03:30:45 p.m.
check direct x version 11/05/2007 03:30:45 p.m.
check if flash is installed and version 11/05/2007 03:30:45 p.m.
Logging ended: Viernes, 11 Mayo 2007 - 15:31"
I'm working on a HP Pavilion a207m:
Operating System: WinXP Home SP2
Processor: AMD Athlon XP 2000+
RAM: 736 MB
Videocard: S3 Graphics ProSavage DDR
I didn´t have this problem with resolume 1.51
now I'll try with version 4.3 to see what happens...
[Edited on 11-5-2007 by maurop88]
Do you have Flash installed? You can do this here:
http://www.adobe.com/shockwave/download ... kwaveFlash
And I see you have XP home edition, we have had some random problems with home edition that are really vague so if you can please try xp pro.
