Record Settings without "Compression" options
Hugo
Record Settings without \"Compression\" options
Post by Hugo »
Im using the lastest version of resolume, and Ive installed the PICvideo M-JPEG Codec v3, but theres no compression options in my record settings. I couldnt find any post related to that, and nothing about it on the manual... Thanks in advance!
[Edited on 24-5-2007 by Hugo]
frederico
Post by frederico »
try right click on the little black dot left to the record button.
Hugo
Post by Hugo »
It didnt work... Its a "picker/slider" configuration button, right?
frederico
Post by frederico »
Forget the little black dot,sorry,just right click on the recordbutton.
scroll down the manual ,you see an example how it looks like.
[Edited on 25-5-2007 by frederico]
Hugo
Post by Hugo »
When I right click on the record button, I have some options, but no compression options... Is there any way to install it?
