Column trigger skips columns
dbf
Post by dbf »
Hello. I have a really strange bug with Resolume 7.21.1 on Windows 11 - sometimes when I click column trigger a column is skipped and the next is triggered. Not every time, doesn't depend on number of clips, and really annoying. Duplicating column and removing skipped one helps, but usually damage is already done. What could be a possible reason?
Re: Column trigger skips columns
Do you maybe have auto pilot enabled on it?
Or the composition?
dbf
Post by dbf »
No autopilot. Sorry for long time to reply, I'm trying to make it reproducible. Still no idea on what conditions it may occur =(
Clips on continue or relative play modes maybe?
