I'm verry happy with resolume and it's functions. but here are some functions tha would make it al go a little bit easier:
Effects:
-it would be nice if you can select in the effect banks on the left side of the screen to wich layers they are aplied (checkboxes for layer 1, 2 and 3). at the moment it's only possible tho apply them to all layers or to a specific file...
- if an effect is aplied to a file i can't find any on/off button for the effect, only the remove [x] button and the intensity slider. am i blind or isn't there anny?
Bpm:
- is it possible to see the bpm somewehre in the mainscreen. at the moment i have to switch tot the bpm tab to see if i have a steady hand/bpm (i use the spacebar to set the bpm)
- if i have the beats function set to 8 beats in the layer and want to go to for example 4 or 16 beats i have to press the buttons too many times. is it possible to place a [x2] and a [/2] button?
- another nice adition would be to place some kind of stripes on the timeline slider that repressent the number of beats chosen. (for example when i have selected 4 beats the timeline is "divided" in 4 pieces so a can easier set up the start and stop frames of the movie.
Further:
-the thumbnail previewer shows the 1 frame of a movie. In lots of my movies (and from others) this frame is black... can't the previewer be made so it shows for example the 5th or 10th frame?
I hope my explanation is good enough.
some new suggestions
That was my wish exactlyEffects:
You can, by pressing the blank square near the x- if an effect is aplied to a file i can't find any on/off button for the effect, only the remove [x] button and the intensity slider. am i blind or isn't there anny?
There is a way, but I forgot... Try searching the forum, I remember there was a thread about that...the thumbnail previewer shows the 1 frame of a movie. In lots of my movies (and from others) this frame is black... can't the previewer be made so it shows for example the 5th or 10th frame?
[Edited on 4-7-2007 by VjSky]
