Projecting a circle?
ref54
Post by ref54 »
Hi there,
Is it possible to mask video in a circle, rather than a square?
I would like to project onto a circular screen and don't want to have to mask off the front of the projector with black card. I was wondering if Resolume can mask the edges of the video square in black and show only a circular image? It would be good to be able to flick between circle and squre too.
Is it possible? If so - how?
Thanks,
D.
frederico
Post by frederico »
there is a circle bmp in the maskfolder.
edwin
Post by edwin »
We made a plugin wich enables you to load a general mask.
check out this thread: http://www.resolume.com/forum/viewthrea ... 8#pid13807
or download directly
http://www.resolume.com/download/theMaskV2.zip
Cheers
Edwin
ref54
Post by ref54 »
Is ther any chance you could add the ability to move the mask left, right, up and down?
I'm using Pete's Pan, Pin and Zoom plug-in with The Mask, but need to be able to moov both plug-ins side to side and up and down.
A single Pan, Pin Zoom and Mask plug-in would be the ultimate.
Any help at all would be great.
Thanks,
D.
