DELL INSPIRON 1501?
tetsuo
DELL INSPIRON 1501?
Post by tetsuo »
Hi!,
what about this dell notebook?
http://www.dell.com/content/products/pr ... l=en&s=dhs
it´s cheap,it will work fine with resolume?.
thank you!. see ya.
It has shared graphics ram so it,s probably not the best option.
VJNemo
bart my dear man...
Post by VJNemo »
ATI Radeon® Xpress 1150 256MB HyperMemory
is not a shared grafic ram isnt it? it's dedicated there for it will be great for resolume right?
I dont know about windows vista- will it run smooth as with XP?
ATI Radeon Xpress 1150 256MB HyperMemory is an integrated graphics solution that uses up to 256MB of system memory, depending on system memory size and other factors. System memory available to the OS will be reduced by the amount of dedicated and shared system memory utilized by this graphics solution.
tetsuo
Post by tetsuo »
hey hey vj nemo!, thanks for the reply, but chill man... jeje.
bart, yes! Ati Xpress 1150 it´s an integrated graphic card... but if i had 1gb or 2gb ram....you say it´s no enough too?...probably the resolume dont work properly?
whatever, i know it´s not the best option, but i don´t have much money on my pocket.... so it´s seems the best price-option as i see...
thanks!.
