I would just like to share with you the solution I found for my installation problem.
In order Resolume to be the "My Documents" folder must look on C: hard disk and not an external HD and the name should not be other than "My Documents".
HOWEVER,
although Resolume starts now it doesn't show neither the effects nor the sources. Besides, it doesn't seem to keep and play the .avi files I drug into the 20 matrices.
I am looking forward for any help.
Panayiotis
instalation ok but nothing is working
how it can be work!
iam new to resolume... but i´ve found an option how it runs
check your boot.ini and make sure u have set the 3Gig Ram switch off....
or do an 2nd boot menu entry
look on my boot.ini
the 2nd option works for resolume... the 1st one is for general use
[boot loader]
timeout=5
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP 3Gg Ram switch" /noexecute=optin /fastdetect /3GB /USERVA=2990
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP normal" /noexecute=optin /fastdetect
maybe it helps
greetz, benni
look on my boot.ini
[boot loader]
timeout=5
[operating systems]
maybe it helps
greetz, benni
