I came up with a list of features that I miss most when i do live gigs:
**Master blackout ( could also be triggerable by dmx ) - Since I often do light aswell it would be nice to be able to instantly blackout everything... ( also it should have a keyboard shortcut asigned )
**Chaos mode keyboard shortcut - I often use chaos mode when I shift my attention on live cameras and i often use my computer lcd as a preview monitor so I can't see resolume and I use only kbd shortcuts... It would be nice to be able to turn off chaos mode without having to switch the display...
**Per layer effect slot or an option to assign a global effect slot to a layer ( something like a switch for each layer, kinda like the rgb buttons ) - I often need more than one effect on a clip or an efect that is permanently applied on a single layer but not the entire video...
**Some vidnet tuning - it always seems to crash
**Maby support for VLC network protokol...It would be nice to be able to use it in resolume...
**Logo owerlay feature ( so you don't need to sacrifice a whole deck to show your logo...)
So, what do you say?
Cheers,
VjSky
[Edited on 4-7-2007 by VjSky]
