Hi everyone,
I have a small problem. In Resolume Arena, I have a video—let’s call it “mapping” for simplicity.
I set it up so that when this “mapping” finishes, it jumps to a blank clip where I wrote a custom OSC out address (/location/1/0/0/press). In Companion, this triggers a button that does the following: on that Resolume machine, it starts a basic loop; on another Resolume machine, it starts a video; it starts a Spotify playlist; and it pushes a fader on the SQ audio desk.
My problem is that whichever Resolume machine I send the OSC command from, no matter what I do in the composition, it always behaves as if I clicked that clip manually.
Does anyone have any idea how I could send a feedback to Companion that the mapping video has finished so that it can trigger the next actions?
Resolume Custom OSC out -> Companion button trigger
phssydstryr
tijnisfijn
- Team Resolume
Re: Resolume Custom OSC out -> Companion button trigger
Whether the clip is triggered automatically from another clip or you click it by hand, Resolume sends the same OSC connect message, so Companion can’t see the difference.
You can work around this in two ways.
1) Listen to the connect state of the blank clip
Let’s say your blank clip is Clip 3 on Layer 1. Its OSC address is:
That address doesn’t just send 0/1, it returns different values depending on the state of the clip (selected, playing, both, etc.).
So in Companion you can do something like:
2) Listen to the position of the mapping clip
A cleaner option is to look at the transport position of your mapping clip, e.g. Clip 2 on Layer 1:
This value goes from 0.0 → 1.0 during playback.
You can put the clip on play once and hold so it stops at one
In Companion you can set a trigger like:
Personally I’d go with option 2 – watching the transport position is the most bullet-proof way to know the mapping video actually reached the end.
Code: Select all
/composition/layers/1/clips/3/connectSo in Companion you can do something like:
That way it only triggers when the blank clip is actually connected/playing, not just when Resolume is doing internal switching.If the value is greater than 2, fire the action.
Code: Select all
/composition/layers/1/clips/2/transport/positionYou can put the clip on play once and hold so it stops at one
That gives you a very reliable “clip finished” signal, no matter how the clip was started.When the position reaches 1.0, trigger the next actions.
