Right after running the software the main window doesn't appear.
It hangs in the tray but doesn't show any windows.
Running ver. 2.41 on athlon xp2500+ 1gb geforce fx5700 (tried with both default and pic codec)
the log says the following:
Logging started: среда, 08 Август 2007 - 22:47 start up 08.08.2007 22:47:57 create my documents folder if not exists for current user 08.08.2007 22:47:57 create application data folder if not exists 08.08.2007 22:47:57 check direct x version 08.08.2007 22:47:57 check if flash is installed and version 08.08.2007 22:47:57 init: previewer 08.08.2007 22:48:01 init: decks 08.08.2007 22:48:01 Not enough storage is available to process this command. 08.08.2007 22:48:01
it's definitely not an hdd/ram problem, everything is more than enough.
