Laptop performance reference
zaniz
Post by zaniz »
If you are in the search for a portable hardware, maybe this topic can help you with some performance reference.
Asus W2J laptop, one outdated machine, but... play 3 layers of 640x480 PICvideo mjpg codec (320x240 process screen), with 2 or 3 effects at the same time, all decks full and a lot of video scratching with no problems for hours (minimum drop frames). Sometimes, when I load a new video, the image freeze for about half a second but it return with no problems at all. I think this is because of the slow HD and low memory.
My Asus W2J configuration: Core Duo T2400 (not Core 2 Duo), 1GB RAM DDR2 533 , HD 100GB 5400rpm, ATI X1600 256MB, with separate partition for Resoume and a Korg K25 midi keyboard.
Any other reference of performance, will be welcome.
coolhandloop
Post by coolhandloop »
i export all my clips 640x480 depending on the mood of my laptop ican usually get away with running 3 layers but once u add effects and so on things can lag a little..sometimes i run process at 400x300 and i can work away grand
toshiba m70 satelite
win xp home
1.5gb ram
128 grphics dedicated
1.73ghz centrino
external hd 7200rpm
messhead
DELL PRECISION M90
Post by messhead »
I've never come across 1 problem what so ever. Not just with Resolume but also Adobe Production Suite and i even played Supreme Commander on 1920x1600 on full detail (Not that thats got anything do with VJ'ing :) ). Handles anything i throw at it at rapid speed. It's a true desktop replacement and its portable. No overheating problems and isnt that noisy either. Only grime is 2 hour battery life but it's always plugged in, even when playing out so thats doesnt matter. And i went for the best screen, 1920x1200 Native and resolume doesnt suppport this resolution. Maybe something that should be addressed with resolume :). I've only used 720x564 videos and had no problem. If your only going use resolume, it's way over-powered, but if you plan on doing any production work such as Adobe's Production Suite, I highly reccomend a Dell M90, And i never thought i would ever say that knowing the problems past friends have had with Dells!!!
Dell Precision M90
Core2Duo T7600 2.33Ghz
2GB DDR2-633
512MB Quadro FX3500M
100GB 7200RPM HDD
1TB (2x500GB) E-Sata HDD
I live in rip-off britain so i imported it from the states for £1,550 delivered off ebay and got them put refurb $399 on it. Customs was £65 so £1,610 in total. If i ordered same spec in the UK i would have payed £2,500-£2,600 so a saving of around £1,000. If your buget reach's £1,500, I'd seriously consider importing!!!
[Edited on 17-8-2007 by messhead]
zaniz
Post by zaniz »
Dear Messhead,
You have a great machine !
I live in a rip-off country too, maybe more than yours!
What is your process screen resolution ?
You get drop frames ?
thanks
[Edited on 17-8-2007 by zaniz]
messhead
Post by messhead »
Originally posted by zaniz
Dear Messhead,
thanks
Well theres only japan worse than the uK so be pretty hard hehe :)
Processing at 320x240, output 800x600. Does that make any difference the proccess resolution? I'm pretty new, well i am NEW to it all but as i said, no problem what so ever so no framedrops. I use the Wiimote as well and that means running GlovePIE & MidiTranslator in the background and still no problems.
Just practicing at the moment and tested it with friends (who are producers and DJ's) with there stuff trying get an act together where i do the visuals and they do the music. They already get gigs and stuff and i want some of the action :)
Despratly want the midi controller though :(
zaniz
Post by zaniz »
Nice setup !
Try 640x480 in the process screen and you will see great improve in the image quality, with your machine, maybe you still dont get any lag.
