ustream.tv live resolume stream possible?
corunography
Post by corunography »
hello,
I recently discovered the ustream.tv website. It allows you to live stream over the net from a webcam. I was curious if it was possible to output resolume to a site like ustream. Can I output resolume as if it were a webcam feed? I would like to start broadcasting my shows live over the net!
Thanks,
Jon
http://www.myspace.com/flexmix
disconappete
Re: ustream.tv live resolume stream possible?
Post by disconappete »
i have streamed low quality on ustream a bunch. my set up is two security cameras into res, and out to a projector on the wall by the DJ booth, then i use ustream producer to capture all of the output visuals coming out of my screen one mix as well as audio that is being DA'd off a separate radio feed. RWD.FM!
even on low quality settings i get crashes when running producer in the background.
specs
3.5ghz dual core amd
16gig ram
OCZ Vertex 4 120 gig SSD(show clips)
1tb 7200rpm(storage)
AMD Radeon HD 7770
windows 7 64bit
