PTZ camera control
jjm35
PTZ camera control
Post by jjm35 »
I have a show where I use Resolume for visuals and to control several live cameras. Until now, the cameras were fixed cameras, but now I want to replace two of them with one single PTZ camera to create two different shots. The idea is to use Resolume’s PTZ control and adjust each shot so that the camera automatically moves to the new framing, and this works very well.
The problem is that the show has 30 songs, and for organizational reasons—so that texts and visuals are not overcrowded on a single Resolume page—everything is arranged with one page or scene per song, switching between song tabs as the show progresses.
At the start of the show, I need to adjust the pan, tilt, zoom, and focus for the two PTZ shots. However, since everything is organized into song tabs, I would have to do this on all 30 tabs, which becomes a tedious task.
What I’m looking for is a way to do this using a variable or something similar—like the different controller types (Timeline, LFO, Basic, etc.)—so that by adjusting it once, all of them are updated. Another option would be for them to receive the coordinates from an external controller or something similar: basically, any solution that avoids having to program 60 PTZ positions for every show.
Re: PTZ camera control
Make the NDI clips persistent: https://resolume.com/support/en/clips?#persistent-clips to have them show up in every deck at the same clip position.
