Screen setup
ElectricExcuse
Screen setup
Post by ElectricExcuse »
Hi there
Maybe a bit of a weird request but i was wondering if you guys could get this feature up and in running in a following major release:
- the ability to chose where to put parts of the resolume main control window on different screens. I'll tell you why :)
I have this small toutchscreen i want to use with resolume but the problem is that the interface is just to big to fit on the screen. But it would be perfect to display clips and decks so i can just tap them to select, also because all the other resolume features are adjustable by my midi controller so i don't need to see them on the touchscreen, i'll have another monitor for that.
Hope you get what i mean
Cheers
gdlt
Post by gdlt »
Sounds like a verry handy set-up if resolume would make a drag and drop interface.
I'm still waiting for someone to design some kind of oled matrix controller Like this:
Optimus mini tree but then 4x4.
