Hi everybody, I will try to be clear even if I talk french...
When I install resolume everything goes good but when I start it, then, nothing happen exept 2 "links" in the task bar (the same that appear when resolume is working), well, the only way it do anything it is when I right clic then it say: Do you really want to close resolume? it is really frustrated! I have a show on friday, have to set it and want to work with resolume! Oh an.. no it is not on my second screen, and yes I did install direct X 9... please if you have any idea that could help!
thanks so much!
Operating System: windows xp
Processor:
Intelî Coreââ¢2 Duo Processor T5600 (1.83GHz1 , 2MB L2 Cache)
Videocard:
Intelî Graphics Media Accelerator 950 128MB Dynamically Allocated Shared (RAM/Video) Memory
File type:
avi
Codec:
indeo 5.11
(but file type and codec wouldn't help... resolume is not starting!)
nothing work! please help!
Re: nothing work! please help!
I know this is an old thread ... but I have the same problem .... start Resolume ... two boxes in the task bar but no way of getting an active screen. Then when you right click and close one of the boxes it brings up the 'do you want to close' grey box. Rebooting will bring it back randomly. But its utterly frustrating.
Any ideas?
Any ideas?
Hey just to say . after posting this I found the other thread on the same subject.
http://www.resolume.com/forum/viewtopic.php?f=12&t=3559
Removing AVG anti-virus seems to fix my problem too. So unless there is a work around then seems a separate partition to run resolume in is the only option (coz I don't want to move from AVG).
