TIGGER CLIPS HARDWARE
RTV
Post by RTV »
HEY guys
i want some advice in which device is the best to trigger video clips. a keyboard or a midi control? some midi controls only have knobs and faders but thats not good for triggering clips. a midi keyboard will do? and whats the cheapest?
thank ya'll
zaniz
Post by zaniz »
Hi RTV,
For me, the Korg K25 http://www.korg.com/gear/info.asp?a_pro ... egory_id=8 work very well, but only have 2 knobs, 1 slider and a customizable weel.
If you want more knobs try the M-Audio Ozone http://www.m-audio.com/products/en_us/M ... -main.html
hope this helps
miau
Post by miau »
Well you have a lot to choose, but I'm not going to say anything about how much they cost.
There is the options zaniz said but there is also others, like:
An POS Keyboard that you can configure at will, very similar to the resolume layout http://www.resolume.com/forum/viewthrea ... 2#pid13656
An Edirol Midi Controler Keyboard PCR-300(500/800), PCR-M30(50/80) and others similar from Edirol also http://www.edirol.com
Or simple use a keyboard with stickers on it.
Check ebay to buy some of these at god price.
