Did i goof up?
r8d
Did i goof up?
Post by r8d »
hi, due to a series of problems i finally out of sheer necessity bought a hp dv9507 because i have a really big gig on saturday, and i needed a machine quick.
its a centrino core2duo T7100 1.8 Ghz / 2 gb RAM/Nvedia GeForce Go 8600M GS/17" mahine, which i now found wont load XP.
So my question is, am i s****d? coz i have a live 40 ft LED outdoor gig on saturday,what should i do?? will resolume run ok on vista? should i look for a replacement(only for the show, am stuck with this one)
gdlt
Post by gdlt »
Check the forum, there are enough topics on running resolume in Vista.
DayVeeJay
Post by DayVeeJay »
If you keep getting blue screen errors there should be a setting for SATA that gives you two options - ACHI or ATA. Try messing with that setting and let us know how it goes.
On a side note, I bought a new Toshiba that came with Vista loaded on it. There where no video card drivers available for XP (at least none that would load properly). Needless to say, I returned the laptop in a hurrry.
