i think its quite basic question.. just wanna be sure
Well.. i've been following VJzoo handbook and i reached problem in step where u're about to install freeframe plugins ( FFPPbasic and Veejay pack 1.1 ). The problem is simple for both - when i am in like 4th step my menu doesn't match with screenshot in VJzoo Handbook - is it right? Ihave different install options ( missing option : veejay'sPack for resolume ) and different 'space required'.
Mb it's just because different resolume version ( mine is 2.41 and theirs is 2.3 ) or i dont know. Is it normal or is there something wrong?
Thank you for answer and help, and i am sorry for duplicating question ( if i do ) but i did'nt found any similar. However thanks for answer!
c u!
kiwii
