Probs with right click
diogo_wdi
Post by diogo_wdi »
I have some problems when I right-click a channel ! :mad:
It simply doesn't appear nothing ! So, for instance, if I want to edit some footage with text I need to right-click it and edit the text, but I can't coz nothing appears ! I think it's kinda problem with the popups in the program coz even when i click the Resolume's exit button, the popup window with 'Are u sure?' doesn't appear, or it appears in the output fulscreen window.
Anyone with anything ? Thankz guys !
[Edited on 13-10-2007 by diogo_wdi]
Thiagoc
Post by Thiagoc »
just came here searching for this answer.
only happens when there are two sreens running
Thiagoc
Post by Thiagoc »
ok here is how i solved it
simply changing the main screen (on windows options) to the projector
and leaving resolumes interface ( screen setup on resolume) on your computer screen
pra resolver eu fiz assim deixei atela principal ( opçoes de video do windows) sendo o projetor e depois nas configurações do resolume puis a interface no pc
