clip triggering midi suggestions
armitageshanks
Post by armitageshanks »
hey all,
currently using my bcr2000 for fooling around with my layers when i perform live but does anyone have suggestions for a piece of good value midi for triggering clips - ie a nice 4x5 drum pad type thing? would love to get my hands on a vmx vj but don't really want two pieces of hardware that do the same thing. any suggestions?
all the best,
armitage
Basic
Post by Basic »
m-auidio
oxygen 8
check out midi keyboards :)
armitageshanks
definately a possibility but was wondering if there is anything out there that more directly corresponds to the resolume layout ie 4x5 layout. cheers though
gdlt
Post by gdlt »
as far as i know al drumpads are 4x4.... so they don't fit the resolume layout perfect.
armitageshanks
that's the problem!
normal
Post by normal »
I used to use the top row of encoders as clip triggers with the bcr2000. Because you can assign four functions to the push setting of the top row I would have the first five push encoders for clips 1-5, then select function 2 for 6- 10, function 3 for 11-15, function 4 for 16-20. Of course this means pressing two buttons to trigger a clip on a different row of the clip trigger matrix but its a workaround not having a bank of 4x5 buttons on the BCR.
Does that make sense?
Manwell
Post by Manwell »
The Codanova VMX VJ controller has a 4x5 button matrix and looks amazing for Resolume. Check it out at Codanova.com
incuf
Post by incuf »
Vmx Vj from codanova, the best option for resolume, I really think it has been made with resolume on designers mind...
