I've been using resolume for a long time and, as a new version is released, resolume fails to find some freeframe plugins of the previous versions and gives an error message on startup:
Plugin 'C:\Arquivos de programas\Resolume2-2\plugins\iscflower.dll' could not be loaded
I put all my plugins on the plugins directory, but the program seems to search in other directories.
Is there a way to fix it manualy? I tried to edit the fx.xml but couldn't find no adress for the plugins. Is there a place where I can try to edit this?
If I click on many 'ok' resolume will work, but I need to solve this. If I create the directory and put the plugin inside it, it will also work, but it should be a better way...
[Edited on 19-10-2007 by 1mpar]
