This feature would be soooo helpful
With a lot of clips, especially ones that have been downloaded, I find that the first frame is often blank. This of course means that I have no preview available and I am often guessing what clip I am about to throw up on the screen. It would be freakin awesome if I could select which frame is displayed on the decks. I dont think that any other program out there has this feature
http://www.resolume.com/forum/viewthread.php?tid=3497
see reply of Bart:
All this will be fixed with the next major version of resolume:
-No moving around of clips (as you posted)
-replace clips without deleting the effect (nice to use the same effect on different clips)
-replace Files when moved to a different Folder/ HD (Search function like in Premiere or so)
-use not only the first frame for preview (Many flash files have only blank first frame)
-use more than one effect on clip
This however will have to wait for version 4 (maybe)
-export decks with content for sharing
-fast search function for clips/decks, perhaps with metatags "
see reply of Bart:
