disable clip after playing
levon
Post by levon »
long time no post...
one thing i think would be cool is a play mode (rather then single play, loop and bounce) would be to disable the clip after its played.
eg: you trigger the clip.. once it has played, it removes it from the layer, this way you could trigger single hit clips that you just need to play once and not worry about it hanging on the last frame until you clear the layer.
Welcome back Levon, loong time so see ;-)
Yes this will be possible with the next version of resolume.
[Edited on 20-11-2007 by bart]
derekg22
Re: disable clip after playing
Post by derekg22 »
So was this released? If so - what is the setting!?
