Resolume Crashing without reason
Evildude
Post by Evildude »
Hi! Recently I have adquired a laptop and I wanted to test Resolume on it. Clean Xp installation, clean codecs, everything like in my desktop machine and... Voila, it crashes when I clic some videos. In the file browser they appears as white boxes with 0x0 pixels and 0 fps. The videos has the same codec that others I've converted have and they play fine and run ok in my desktop Resolume.
I've reinstalled Directx, and the same codecs that in my desktop. WHYYY!
The log shows nothing:
Logging started: martes, 11 diciembre 2007 - 22:04
start up 11/12/2007 22:04:24
create my documents folder if not exists for current user 11/12/2007 22:04:24
create application data folder if not exists 11/12/2007 22:04:24
check direct x version 11/12/2007 22:04:24
check if flash is installed and version 11/12/2007 22:04:24
init: previewer 11/12/2007 22:04:28
init: decks 11/12/2007 22:04:28
init: file browser 11/12/2007 22:04:28
init: fx 11/12/2007 22:04:28
init: sources 11/12/2007 22:04:29
init: preferences 11/12/2007 22:04:29
load avaliable MidiInput devices 11/12/2007 22:04:29
Init Midi Controller list 11/12/2007 22:04:29
Init Midi Notes list 11/12/2007 22:04:29
Init Key list 11/12/2007 22:04:29
Init Audio Capture device list 11/12/2007 22:04:29
Load settings 11/12/2007 22:04:29
Set Midi Input devices 11/12/2007 22:04:30
Init DMX 11/12/2007 22:04:30
Save settings 11/12/2007 22:04:30
gather preferences 11/12/2007 22:04:30
gather channel keyboard shortcuts 11/12/2007 22:04:30
save preferences and keyboard shortcut settings 11/12/2007 22:04:30
gather midi shortcut settings 11/12/2007 22:04:30
get midi channel/ layer shortcuts 11/12/2007 22:04:30
copy midi channel/ layer shortcuts 11/12/2007 22:04:30
copy midi controller shortcuts 11/12/2007 22:04:30
get midi effect shortcuts 11/12/2007 22:04:30
get midi channels 11/12/2007 22:04:30
save midi shortcut settings 11/12/2007 22:04:30
save dmx settings 11/12/2007 22:04:30
init: shortcuts and midi 11/12/2007 22:04:30
init: recording 11/12/2007 22:04:30
init: audio fft 11/12/2007 22:04:31
init: render 11/12/2007 22:04:36
init: bpm 11/12/2007 22:04:36
init: screensetup 11/12/2007 22:04:36
firsttime get displays 11/12/2007 22:04:36
firsttime copy display setups 11/12/2007 22:04:36
finalize screen setup 11/12/2007 22:04:36
destroy screens 11/12/2007 22:04:36
create screens 11/12/2007 22:04:36
search main dxdraw 11/12/2007 22:04:36
set dxdraw resolumedraw 11/12/2007 22:04:36
position mainscreen 11/12/2007 22:04:36
check for dvdmax 11/12/2007 22:04:36
set global settings for multi and single screen 11/12/2007 22:04:36
initialize all screens 11/12/2007 22:04:36
dualscreen is false 11/12/2007 22:04:36
initialize dxdraw 11/12/2007 22:04:36
--------------begin intialize-------------- 11/12/2007 22:04:36
creating overlay if needed 11/12/2007 22:04:40
create surfaces 11/12/2007 22:04:40
width:320height:240 11/12/2007 22:04:40
create vidnet object 11/12/2007 22:04:40
create spectrum surfaces 11/12/2007 22:04:40
create watermark surface 11/12/2007 22:04:40
create system surfaces 11/12/2007 22:04:40
create system preview surfaces 11/12/2007 22:04:40
create directshow movies 11/12/2007 22:04:40
create vfw movies 11/12/2007 22:04:40
check quicktime and create movies 11/12/2007 22:04:40
check for capture devices 11/12/2007 22:04:40
create dibs for pictures 11/12/2007 22:04:40
create picture objects 11/12/2007 22:04:40
create picture dib objects 11/12/2007 22:04:40
create plugins 11/12/2007 22:04:40
create flash 11/12/2007 22:04:40
again try dvdmax if not created and if supported 11/12/2007 22:04:40
get bltcaps 11/12/2007 22:04:40
--------------end intialize-------------- 11/12/2007 22:04:40
assign additional screens to resolumedraw engine 11/12/2007 22:04:40
position displays 11/12/2007 22:04:40
set screen setups 11/12/2007 22:04:40
start render engine 11/12/2007 22:04:40
render engine started 11/12/2007 22:04:41
init: load startup decks 11/12/2007 22:04:41
getPreview C:documents and settingsresolumeescritorioangryboy1950_monedero.mov 11/12/2007 22:04:57
read preview from disk C:documents and settingsresolumeescritorioangryboy1950_monedero.mov 11/12/2007 22:04:57
Any ideas?
Its Dual core 1.81 with intel 128mb 945 Video card, and 2 gigs ram.
nwonknu
Post by nwonknu »
Maybe cause your trying to play MOV files, stay away from that evil :mad: :D
Try to instal quick time alternative
Evildude
Post by Evildude »
Quicktime alternative is installed too, maybe the evil it's windows itselft...xD
nwonknu
Post by nwonknu »
Just avoid mov in resolume, they dont like each other :(
gdlt
Post by gdlt »
I have the same problem with some mov's they DO work on my xp laptop but crashes on my vista laptop (also white boxes and crash when clicked)
see my update in this post:
http://www.resolume.com/forum/viewthrea ... 0#pid15424
But i'm happy to hear vista i isn't the reason. I think it must be some kind of forgotten codec or something like that.
