Because I'm A Newbie...
newsosa
Post by newsosa »
Ive only just started to play on resolume and at the moment am only using the sample clips and some downloaded ones. On the 'text' sample video, i notice the effect is set to 'zoom'. is there anyway of changing the effect on this or will i have to make a completely new one? if so how do i do it? sorry to be a pain but i dont know what im doing really.
gdlt
Post by gdlt »
right-click the clip, in the pop-up there will be a"x" in the corner, click on it,problem solved.
