How can I capture images from other software?
VJ_Chico
Post by VJ_Chico »
Hello, how can I capture images from other software without using screencapture, it is works but is very limited!
Thanks.
edwin
Post by edwin »
Try this,
VH Screen Capture Driver
http://www.hmelyoff.com/index.php?section=1
Edwin
Ikyut
Post by Ikyut »
Try Gadwin printscreen. It works for me. set the rectangular area on the Source label and you will use yoy mouse to select the area. and the software your you a 4x zoom on a mobile flying screen.
http://www.gadwin.com/printscreen/
Ikyut.
