geforce 4 t1 & video capture
adam_
D250_
I also have some problems with the Asus Gf4... video card, the picture from the capture device makes the output flicking, that means, random frames nearly every 6th are truncated nearly at the half picture , the upper left stays normal, the rest is moved to a random position. I use a webcam with composite input now to get a live picture, but the webcam can’t be forced to run at 640x480. ...D250.hu...
adam_
it seems to have sorted itself out. i changed a few settings and whatnot and it seems to work fine now. it's still glitchy.
i get the same problem with the truncated picture. all you have to do to sort that is add the 'light' effect from the generators list and put it to zero in that channel. it wont work if you apply it to the clip in the deck. you have to add it to the channel the vid is palying.
hope that helps
hope that helps
