Hello
I'm quite new to Resolume but after some success in ploughing my way through it, I started to experiment with flash and found that while I got it to work, after a few seconds Resolume apolgised - very politely - and closed its doors. It does this every time with flash files; with everything else is fine. Any reason for this?
Spec - windows XP
Intel Core 2 Quad PCU 2.66
2 Gig RAM
NVIDIA GeForce 7300 LE
Thanks in advance!
Flash files crash Resolume
craftycurate
Re: Flash files crash Resolume
I'm having this problem too. It seems to happen with certain Flash anims and not others.
It may be to do with scripting ... one anim almost always crashes R2.41 when I start playing around with the rparameter1 slider in the FLash properties section.
Could someone at Resolume please comment on this? I'm close to being a customer, but as I use a lot of Flash files in my stuff, I need to know if this is an issue or if it can be resolved before I spend the cash.
Richard
Richard
