Hi, I tried to install resolume in my mac and i can't, that happens because are not compatible???
.exe is not working on mac
Problems Mac
Re: Problems Mac
Resolume is Win only.
But if you have a new intel based mac, you can install win xp/vista on it and run resolume without problem
Re: Problems Mac
Yeah just bootcamp a windows partition, get ur codecs together and quicktime installed if ur using movs and ur away. I
